GPO on the LCD2041-WB
SilmarilS
Post by SilmarilS »
I have a simple question....
Is the GPO on this unit (20mA) is enought to supply a single green To 3/4 LED... directly
linear
evil Dr. linear
evil Dr. linear
Post by linear »
Simple answer: yes. :D
SilmarilS
Post by SilmarilS »
Simple answer2: Thank You....
It works but I like to have more gpo's...maybe my next MO will have more :(
linear
evil Dr. linear
evil Dr. linear
Post by linear »
Here's an option: if you run LCDC, check out the parallel port plugin (LPT). It's effectively 8 GPOs for you to control from LCDC if you have a free port.
IF you don't run LCDC, you should.
SilmarilS
Post by SilmarilS »
It's start to sound good...
I run LCDC and have a free LPT port..... :)
my printer is networked on another computer
can you provide me a link or the way to convert the LPT connector into a module to use GPO's....(will be simple leds)
Or the LPT pinout
thanks
Mat-Moo
Post by Mat-Moo »
I build a led test module this way. http://www.angelfire.com/mb/lalim/images/parallel.htm although the control at the moment for the LPT stuff is not as good as the native GPOs stufff, but I need to do a bit more work on that plugin.
SilmarilS
Post by SilmarilS »
next week-end I will try this...very easy...it is all I need....
SilmarilS
Post by SilmarilS »
I was wondering if you could use the LPT port as a input one....
like using 4 ports to 4 buttons and the rest as 4 gpo's?
Mat-Moo
Post by Mat-Moo »
With most the MO screens offerinf 25 inputs it's not something I've ever looked at.
SilmarilS
Post by SilmarilS »
Ok so I must forget using the LPT port as a input?
linear
evil Dr. linear
evil Dr. linear
Post by linear »
Well, he's just saying you'd need to code it yourself.
Examples abound on the web. The smart way would be to write an LCDC plugin, but that's assuming you can deal with Delphi.
SilmarilS
Post by SilmarilS »
Yeah I can code it my self but it will take light years to do so :(
but the only gpo alterative is enough for me.....
