I just bought a LK204-25PC two months ago. It's works fine until last three weeks.
I put on the CPU and the LCD go on but don't show the logo. Then, i work on the pc and two hours pass the LCD show the logo . If i restarted the pc the LCD works fine, but if i put off the pc and then put on the LCD put on the light but don't show the logo again.
I put a switch in the +5V power cord. If i push the buttom the power doesn't go, buy if i don't push it goes.
Well when i power on my computer the lcd don't show the logo. If i push the switch some times (three, four or five normally) the lcd displays the logo and my LCDC program works very well.
I'm happy for my display works but i don't like the solution.
Can you explain me the problem? Can you send me a solution more proffesional?
a) Is the ground properly grounded to your power supply?
b) Are you getting 5 volts at the display?
c) How big are your wires when you built the power cable?
d) What actually might be running your display is leakage current coming down one of the data lines.
