Inverse Blue!!!!!!!!!!!!
The LK204-25-WB has been released as of today! For all the people who plan on using the display in a computer, make sure to get the Wide Voltage model!
http://www.matrixorbital.com/products/lk204-25.htm
_________________
<font size=-1>[ This Message was edited by: Henry on 2002-08-23 11:54 ]</font>
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
Super nice... would prefer it with the -PC controller though :wink:
Rob.
psykik
Post by psykik »
Hey Henry before i order this,
Which mounting kit works with it?
Do you have an aluminium mounting for it?
Are you planning a version of this lcd which can be used as a baybus too?
thanks
OK, the LCD2041 versions are in as well!
http://www.matrixorbital.com/products/lcd2041.htm
MK2041 for just a mounting kit and the B2041 for the PC Bay insert
No.
Not anytime soon, but in the long time future maybe.
Gimm_MO_NOW
Post by Gimm_MO_NOW »
Thank you Henry.
You don't know how much I've been waiting for this.
I'll link some pics of my clear case once I mount the LCD.
Looking forward to it :grin:
Gimm_MO_NOW
Just before I order the module, is voltage input the only difference between the regular and the wide voltage module?
Also, is it safe to use power source from pin 9 of serial connection from motherboard instead of the cable provided by the power supply? The manual says the module will die if the power goes above 5.5 volts.
Can I use above methode for the wide voltage module?
Computer power supplies are not nice some times when it comes to voltages. Using the Wide Voltage model will keep you unit safe incase there is a voltage spike... if you plan on powering the LCD through the DB-9 connector you might as well het the standard voltage one. Also, the LCD will draw about 100mA of power, so you may want to check that the motherboard will provide that much current.
psykik
Post by psykik »
does the BVF2041-BK come with a VFD or is the price alone $141.75 ?
If not, the LK204-25vpt $94.05 + drive bay insert $141.75 = $235.80 ( that right? )
what other wires would i need to buy from you to make this work right out the box?
thanks
The BVK2041-VK comes with the VFD (VFD2041-V)...
To make the LK204-25-WB-V in a insert, get the display and then a B2041-BK (or what ever color) and everything will be there for you.
