I just recieved this beautiful VFD the other day and i am hitting a little snag. When i have it hooked up to power AND a serial port, I get random 'stuff' on the display immediatly after powering up, even before my pc can post. However if I remove the serial cable and only give it power, it boots up perfectly fine and i get a nice blinking cursor in the corner. As far as I've read, the serial cable is just a plain old straight thru rs232. I'm using my internal com port header so it doesn't have to loop outside the machine. I've hooked up my "other brand" display the same way and it was fine, but I just had to get the super nifty VFD.
If anyone has experienced similar problems, or know how to fix it, please lemmie know.
<font size=-1>[ This Message was edited by: dVs on 2002-04-30 02:24 ]</font>
Having trouble with a VFD2041-V-E
I tried a few new things today. I rigged it into my other machine real quick to see what would happen. I disconnected my C**********z dieplay and hooked up the MO one and it booted up fine without the crap. my FREEMETER program didn't display correctly, but thats ok, the MO demo program and LCD SMARTIE 5 worked perfectly. Ok, so I know the display itself is fine, but I still can't figure out exactly why it doesn't work in my main system. Could it be a VFD vs LCD issue, or maybe a internal com header/cable issue? I've used the com header and cable before without power on problems, but not with a VFD. I'm going to go pick up an external serial cable to see if that changes anything becuase I gotta stop by the hardware store anyway to get more split loom and spiral wrap. I'll post any findings i get for anyone who may be having the same problem as me.
Here are my critial system specs:
AUSS p4s333 motherboard
400watt power supply
db9 to 9pin serial header cable
correctly modified power cable (i check many times over)
lian-li pc-65 case
lian-li pc-65 case
