Flow control mode on GLK12232-25SM
thrust
Post by thrust »
Hi!
I can connect and send data to my GLK12232-25SM using visual c++. (Using CreateFile, WriteFile) But the display generates unpredictably results when the buffer is full so therefore i suppose the flow control mode would be the apropriate solution.
Any one have some source describing how to do this? I guess it will involve some overlapped communication, but im not sure how to do this.
Any help would be appreciated,
/Oskar
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
The bit in the manual describe how to use flow control pretty well... though if you're really stuck give mat-d-rat a bell, he put it in LCDC.
r.
Mat-Moo
Post by Mat-Moo »
As Cheese says, in the manual there are control codes yo usend to turn on/off flow control - but you must rememebr to do that on the com side too. I just change a couple of parameters on the comport control I use so I can't really help any more than that.
Here is some C source code...
http://www.matrixorbital.com/faq/ex4.htm
thrust
Post by thrust »
Hi again!
The problem is not really how the commands on the diplay works, rather how to implement it under Win32.
I have something that almost works using overlapped communication and a thread that waits for signals from the display. The problem is the reading thread behaves okay in debug-mode but produces really strange results in release-mode. Another problem is that the reading thread takes almost all processor cycles. Any help on how to solve this would be apreciated.
Thanks in advance,
/Oskar Sj
