is there a way in GTT Designer 2.5 to conditionally display a button or to disable it's visibility when another button has been pressed?
I would like to have one 'master' button cause a number of other buttons to show up on the display when the 'master' button is pressed and then have the slave buttons disappear when the master is pressed again.
I looked through the GTT Designer YouTube tutorials and didn't quite find what I was looking for.
Regards,
Sean
Conditionally display a button or disable it's visibility
Re: Conditionally display a button or disable it's visibility
Hello Sean,
Out of the box, it cannot be done, but what you could try is to make two screens, one with the buttons, one without, and navigate between them.
These two screen should look similar so the navigation would look seamless and just the buttons showing up.
Hope this helps.
Hope this helps.
