Digital Baybus
I like what I see out of the LK204-25PC, however, I was interested in knowing if any of the other Matrix Orbital units can do what this one can. I would prefer to have a graphical unit or a VFD unit. They just look better to me. Is there going to be something new coming out along these lines?
My requirements are:
1. Be able to turn on/off 3 different lighting modifications in any combination. (LED lights, badge light, and cold cathode tube light)
2. Be able to turn on/off 2 case fans in any combination.
3. Be able to display temperature, CPU usage, Winamp, etc. (I assume this is all done through downloading a program from your site)
How would I be able to toggle these things? Could I put some push buttons on the side of the bay bracket to scroll through a menu, or would I have to use a keypad? And finally, is any of this possible on a smaller unit? (that would fit in a single 5
Actually, the LK204-25PC has 8 high power outputs (didn't see that before), so it would work exactly for what you want. I was just proposing an alternate solution but the LK204-25PC should work out fine for you (I'm actually wiring up the parallel port to control fans on a little computer me and a friend are putting together). In terms of using a graphical, however, the most GPOs they have is 2 outputs, and they are not the high power GPOs like the LK204-25PC. You can use them to switch higher loads using transistors, but in the end, it would probably be easier with the character rather than graphic lcd.
[edit]I'm tired, it's early in the morning, just finished watching Memento, please exuse my grammar
[/edit]
-special [k]
_________________
"An unsupervised teenager with a modem is as dangerous as an unsupervised teenager with a gun." -Arizona State Attorney Gail Thackeray
Chemical name: Cyclohexanone, 2-(2-chlorophenyl1)-(methylamino)-cyclohexanone hydrochloride, C13H16ClNO
<font size=-1>[ This Message was edited by: specialk on 2002-03-07 23:35 ]</font>
-special [k]
_________________
Thanks for your reply.
I guess my final question now for Henry or anyone else who might possibly know...
Are there plans for a graphic or VFD serial display with high power GPOs to come out anytime in the near future. I would hate to buy the -PC and have a new one come out a few weeks later.
Thanks again!
Thanks again!
Software still has to control the GPOs in the sense of if you press a key on the keypad the LCD will only fire that command over the serial port and not do anything with it. The software/hardware has to do something with the keystroke, like tell the LCD to turn on the GPO.
That is the answer I was looking for. Thanks Henry!
One final thing now before I order, what comes with the unit when I order it? Do I need any additional things besides a mounting brakets?(cables, etc.)And also, where should I order a keypad from? It doesn't look like Matrix Orbital is selling them, or are they?
I just need a simple 4-5 key keypad. Do I order a 12 key keypad and only use what I need? Where should I get one and what model would you recommend?
Thanks again!
Thanks again!
If you order the LK204-5-PC, nothing comes with it, just the display.
*B2041 will get you pc bay insert + power cable + serial cable
OR
*Serial cable
*Power cable
*Mounting kit
We only sell the 4x4 keypad, you can get another one, jameco has a number of them. All you need is a matrix style keypad to make it work.
OR
*Serial cable
*Power cable
*Mounting kit
