LCDC
turn line wrapping on...
Nerk01
Post by Nerk01 »
I see you have a seti plugin in how about an RC5 plugin for dnetc
Mat-Moo
Post by Mat-Moo »
lines 2/3 swapping fixed (still not sure what was wrong!!)
Mat-Moo
Post by Mat-Moo »
If someone can tell me how to get info out of it, it shouldn't be a problem - or if anyone wants interface code that ok too...
CyPher
Post by CyPher »
i just downloaded it and installed it again...line swapping is working fine here also....i was going to mention that the fade effect wasent working, but its working good now.....
Mat-Moo
Post by Mat-Moo »
I'm just sorting a couple of other minors - a memory leak in the MM5 plugin is sorted etc...
CyPher
Post by CyPher »
cool...ive been playing with it for the last hour.....ive got the prog loading up upon startup...but is there a way to have it also start the display without haveing to bring up the prog and click the start/stop display button?
Mat-Moo
Post by Mat-Moo »
it remembers the state it was in when you closed it - so if you close without stopping it will start again when you run it...
CyPher
Post by CyPher »
cool..i just discovered that actually....its a hit or miss thing with my system though.....the system does something with the com portsright after bootup... (if i dont load any lcd software, a few garbled characters will appear on the lcd) so for the first second or two, the port is not avalable and gives an error if the lcd software tries to load....this only happins every so often though (happins with other software also), usually the software loads right up....
maby you should have it delay a 2 seconds or so before loadup in case anyone else has this prob....(i think it might have to do with my audigy/live drive, as it never happined before it)
something to think about...
Atarien
JackyPC
JackyPC
Post by Atarien »
On 2002-03-08 11:11, Henry wrote:
On 2002-03-08 10:58, Atarien wrote:
good work !
are you planning to suppport LK-202-25 Keypad and GPO ?
They are... all you have to do is configure it...
sorry i had an older version !
works great ! best LCD Prog ever ! Keep working !
Mat-Moo
Post by Mat-Moo »
Ok - I've updated the files to fix all the silly bugs posted so far! Thanks for the comments etc...
morpheus
Post by morpheus »
Help i install LCDC under Windows XP
When i start it he says : "Unable to locate Processor performance objet"
and when i trie to do something i lcdc say erroe on save :sad:
HEEEELLLLLLPPPPPP
My Processor is a PIV 1.80A
morpheus
Post by morpheus »
One more i have teste the borlndmm.dll with testdll.exe and it say :
fail ton find initialise in plug in borlndmm.dll, when i click on ok it say "error loading plug in" and i am in the test prg but evry where i have acces violation .....
Mat-Moo
Post by Mat-Moo »
Okay the CPU thing will have to come out... the borlndmm.dll is not a plugin - its just a helper file for the app to work :smile:
morpheus
Post by morpheus »
Ok but why can i do nothing under Lcdc?
I cant configure it ...
I cant use the screen builder (acces violation)
? do i wait a other version ?
snif
