hello,
i have a vk204 -25 usb and i don't know how to write text to it using visual basic according to the manual i need to send 0xFE 0x58 to clear screen
can anyone help me? i don't understand how to send the data
i'm using vb and the code is
serialport.write (&HFE)
serialport.write (&H58)
and it doesn't work
if u can send me example it will be helpful
I'm more of a C type languages guy myself, but I worked out a little program here for you this morning; it seems to work quite well.
Imports System
Imports System.IO.Ports
Module Module1
Dim WithEvents Port As SerialPort = New SerialPort("COM1", 19200, Parity.None, 8, StopBits.One)
Public Command As Byte() = New Byte(1) {254, 88}
Sub Main()
Port.Open()
Port.Write(Command, 0, 2)
Port.Write("Hello World!")
Port.Close()
End Sub
End Module
I always like to use the decimal equivalents when coding, but you should be able to throw in the hex values instead. You'll have to change your COM number to match the one your display is attached to; I'm guessing it'll be a higher number as you'll have a virtual serial port. You you're not sure, you can check out the number in your device manager.
If you have any further questions, just post, and I'll do my best.
hi
this was very helpful
can u help me with my project?
i trying to make equalizer using vb how can i get information about how to do it
'how to get data from media player - artist name,album name and ....
Although we'd love to help everyone with all their programming issues we really can only give you support on interfacing with the LCD. For obtaining data from media player you are on your own. You might want to checkout something like LCD Smartie instead that already does a ton of these things.
Although this is not strictly LCD related, when I wanted to write details of what was playing in Windows Media Player to my Matrix Orbital LCD as part of a custom Visual Basic program, I used the following 'blogging plugin' which populates a registry key with the details of a song playing in WMP: http://www.microsoft.com/windowsxp/down ... reate.mspx
I then adapted the C# code I found at Codeproject to read the relecant registry key. http://www.codeproject.com/KB/system/re ... nitor.aspx
I then used the method used by Clark above to write the data I wanted to the LCD.
If you cannot manage to adapt the Registry Reader code from Codeproject for your own VB use, I may be able to share the very simple VB implementation I am using myself.
hi im using windows 7 an media player 12 i cant install the bloger plz help
i will be very happy if u can share any code u have i want to make my own display for media center (i have the thermaltake medialab and i want to replace it)
I am afraid I do not know if the blogging plugin works with Windows 7 and WMP 12 - I am using it only with XP and WMP 11. I cannot offer help with this, you would need to look elsewhere - maybe Microsoft have an updated tool, or place this in a different registry key in Windows 7.
The following code works for me in XP and WMP 11, using the bogging plugin, and having added the dll from Codeproject into my VB program. It is partly taken from MS blogs and partly from the codeproject page referenced. It works for me but I cannot vouch for it as I am a very amateur coder, so I cannot offer any further guidance - maybe asking at a Windows Media Player or General VB forum elsewhere would be more fruitful.
Public WithEvents registrymonitor1 As RegistryMonitor
Public Sub StartMonitoring()
Dim keyName As String = "HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer\CurrentMetadata"
registrymonitor1 = New RegistryMonitor(keyName)
registrymonitor1.Start()
End Sub
Public Sub registrymonitor1_Error(ByVal sender As Object, ByVal e As System.IO.ErrorEventArgs) Handles registrymonitor1.Error
Console.Write("error")
End Sub
Public Sub registrymonitor1_RegChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles registrymonitor1.RegChanged
Console.WriteLine("REgistry Change Called")
RefreshMetaData()
End Sub
'The following subroutine is called when a song is started or stopped
Public Sub RefreshMetaData()
Dim newMetadataAvailable As Boolean
Dim newAuthor, newTitle, newAlbum, newDuration As String
Dim CurrentMetadata As RegistryKey
'This tells the program what key to find the WMP Blogger info at
CurrentMetadata = Registry.CurrentUser.OpenSubKey _
("Software\Microsoft\MediaPlayer\CurrentMetadata", _
False)
With CurrentMetadata
newAlbum = .GetValue("Album", "No Album")
newAuthor = .GetValue("Author", "No Author")
newDuration = .GetValue("durationString", "No Duration")
newTitle = .GetValue("Title", "No Title")
End With
If CurrentMetadata.ValueCount > 0 Then
nowplaying = "playing"
newMetadataAvailable = False
If (newAuthor <> regline1) OrElse _
(newTitle <> regline2) Then
m_Album = newAlbum
m_Author = newAuthor
m_Title = newTitle
m_durationString = newDuration
m_LastRefresh = Now
'This reads the data I want for the current playing song and puts it in a previously declared string that I can write to my matrix orbital LCD using the code Clark mentions above.
string1 = m_Author
string2 = m_Title
End If
End Sub
