Fan controller?
Fan controller?
Hi all
Will the typhoon be able to control fan speed, if so will the be possible to do via remote or will it be software orientated.
How long now till its release?
marl
marl
Right, the Digital Baybus is an addon card, this way we were able to keep the GX as inexpensive as possible and when the Digital Baybus addon is released it will allow us to add on features we could not normally put on.Markatomic wrote:So if I was to bu it when it is releases in a couple of weeks it WONT be able to control fan speed?
mark
- LCD Geek
P.R. rewrite: As soon as 8 weeks! Engineering will only release the design after it has been refined. We only release quality projects, so this may require an additional 2 weeks.Henry wrote:minimum 8 weeks more like 10... depends if engineering gets it right the first time
![;)](./images/smilies/icon_wink.gif)
![Image](http://2geek.org/images/cipher_nemo_sig_modding.jpg)
WorkPC: http://valid.x86-secret.com/show_oc.php?id=242197
Gaming Rig: http://valid.x86-secret.com/show_oc.php?id=274345
My blog: http://2geek.org
This one is up in the air still. If it is controlled by pulse, it will be up in the 30+KHz range to keep it WELL outside the audible range, and if someone is inclined to put a light on there, outside the visual range. Overall, pulse is much simpler to design, and far more flexible, but we will NOT use it if there is any audible or visual artifacts.
However I'm still kicking around a few designs that are voltage controlled. The main difficulty with them is designing them for a reasonable price while being able to handle the power requirements of the higher end fans. We're targeting about 12W max (1A at 12V). Anyone who knows electronics, knows that this is quite a bit of power to control.
Then there is the hybrid designs that have been contemplated...
Bottom line, for now, both have been crudely prototyped, and both are under consideration. Right now we're experimenting with half a dozen different designs, and we'll finalize on one when we move our focus back to this project.
James McTavish, P.Eng
Director of Engineering
With my existing display (from you guys) which is pulse, I'll swear the fan generates noise at certain speeds that it wouldn't by voltage control? Am I mad or is there something in this?Paradigm wrote:This one is up in the air still. If it is controlled by pulse, it will be up in the 30+KHz range to keep it WELL outside the audible range, and if someone is inclined to put a light on there, outside the visual range. Overall, pulse is much simpler to design, and far more flexible, but we will NOT use it if there is any audible or visual artifacts.
- LCD Geek
NeilF,
It depends on the type of fan and its ability to handle pulse-width modulation (PWM) verses more traditional throttling via a flux density waveform. The differences could cause a fan to either not function or generate extra vibrations and/or noise. Not all DC fans can be controlled well using PWM.
But may be I'm reading your question wrong? Let me know if that helps.
No, you're not hearing things. Our previous motor controller did use pulse control, however it did it at a much slower rate. The result is that there are artifacts within the audible range. On some fans, you really couldn't hear it. On others, you definitely could.
If we do go pulse control on this next one, it will be in the order of 1000 times faster. This would push any artifacts, or harmonics there of, way out of the realm of human hearing.
