Hello, I am having an issue install the 5 1/4 bracket. The screw holes do not align up with the case frame. Has anyone used a Hard Drive bracket the works? This frame has only center holes not the dual like the mount.
Sorry to hear that you are having trouble with your installation. If you could get the bracket model number and PC case model I will have better understanding of your problem, and can start working on a solution here in the lab.
Thanks for getting those details. I have contacted one of our local suppliers to try to get a similar case, but unfortunately they do not carry the Fox Conn brand so I am unable to be much more help at this point. Short of modifying the mounts yourself, the only advice I can give you is to keep checking the forums here to see if anyone else has had a similar experience.
Good luck with your hard drive mount, I hope you can get it worked out,
