LCD Smartie 5.0 release
it loves the 4x20 lcds... make sure you set the size in the main windows... BaiseP has a 4x40 so everything is setup for that...
[VH]sn1per
[VH]
[VH]
Post by [VH]sn1per »
it loves wolfies graphical 122x32 glk12232-25-wbl lcd too ;p inside joke with henry...it loves everything i have thrown at it...even a v1.0 cf 16x2 636 lcd..shut up henry..i told you i had that one ;p
BasieP...one hell of a program brother...if i find any things that could be worked on i will let you know...so far, i haven't found one bug at all...except for the v1 cf...but i don't give a shit about that one since my main ones will be MO from now on...
NotANick
Post by NotANick »
Works just fine with my 4x40 as I stated before but there are a few things I'd like before I switch over to this full time instead of LCDCenter. All were listed in my last post and most were address'd by Basie already. :smile:
The only ones he didn't comment on were
Net Stats:
Local Host
incoming network traffic (in Mb)
outgoing network traffic (in Mb)
network adapter name
incoming and outgoing being the most important to me.
*sigh* I gotta remember to check my spelling BEFORE hitting submit
<font size=-1>[ This Message was edited by: NotANick on 2002-01-26 07:47 ]</font>
eh, no body's perfect...
CyPher
Post by CyPher »
nice prog......ide use it all the time if i diddent have to close the prog first in order to get my system to shut down......
I noticed that as well, but it's not always for me...
CyPher
Post by CyPher »
any chance that shutdown bug is going to be fixed soon?
also, a few things ide like to see implemented.....
-an option to automaticially hide the program
-gpo on/of option for the input config
like those bars though
that's there all ready... start the program with a -hide on the end... and I'm not sure what you mean with the GPO thing?
CyPher
Post by CyPher »
ok...got the hide thing working...i hwould of thought of that.
as for the gpo thing, there seems to be opions ther ein the matrix orbital settings, to set up inputs to controll winamp etc....ide like more options there like turning the gpos on/of etc via an input...that way you could have the fans controlled via temp, and still have a manual option to turn them on with out haveing to wire up more circuts....say, hit an input, and suddenily your winamp control switches become your fan control switches.....
twain4me
Post by twain4me »
hmmm not fair mine still isn't working...
it looks like the program screws the fonts on the lcd.. it displays the first screen almost ok ( its to big for the screen) but then it gets very bad.. now the fonts are unreadeble for Mogd :sad: have to pul the power and download the fonts.. :sad:
a hint anyone??
win 98se
winamp 2.77
mbm 5.1
smartie 5
glk12232
no programs working on background
slow down the scroll rate, that's important...
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
I've never got it working with my glk-12232-25 either... if someone has I woulnd't mind a copy of the config file?
r.
twain4me
Post by twain4me »
:sad: again.... glk-12232-25 working bad with software...
or maybe the hardware...
or..
Its the usser. ===>user error. you ar a idiot<===
Anyway its not working :sad:
[VH]sn1per
[VH]
[VH]
with my glk12332-25 it is so close...it can be hit or miss every now and then...the scrolling i think is what causes it to go goofy...other then that it rox all around...forgot to add...if the lines are static and not scrolling mine works fine...it may get a little goofy every now and then when changing screens...i am using the Small Font to make the glk as close to a 4x20 as possible...henry just said the same exact thing on icq
<font size=-1>[ This Message was edited by: [VH]sn1per on 2002-02-06 17:10 ]</font>
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
Yeah same here... the problem is the scrolling technique - but it does make it unusable... (don't like garbage me!)
:grin:
r.
