L@@king for a standalone hardware/software project
nk-nk
Post by nk-nk »
I want to use the display in a non-PC application. I want to monitor a number of temperature points and maybe a few digital points. I don't have the time to learn how to do it from scratch. soooooo
Can someone point me towards a project that has a dedicated micro (or Win CE device) driving the display with temp and digital points?
NK
Jon
Post by Jon »
Hi NK,
Sorry I don't know if I understand exactly what you are looking for. If you could clarify what it is that you are trying to do I may be able to help a little bit more. Thanks.
Jon
nk-nk
More specific
Post by nk-nk »
I want a stand alone micro, monitoring a TBD number of temperature points as well as TBD digital points on the 1-Wire bus. The results to be displayed on the Matrix Orbital display. I don't want a PC/Win based system due to size, cost and time to boot.
A standalone weather station application is similar to what I'm looking for.
I've looked through the app notes relative to the Javelin and Pic micros. The temperature module is a good start.
Thanks for helping,
NK
AJB2K3
Post by AJB2K3 »
you would be better off learning about the pic micro and using a raw lcd.
Jon
Post by Jon »
Using a raw lcd can be quite time consuming and then you wouldn't be able to take advantage of our keypad interface, gpo's, or 1-wire bus. (never mind the other built in functions such as bar graphs, large/medium numbers and custom characters)
The 1-wire bus that we have built right into the majority of our displays should make your life a lot simpler. I am glad that you have found our appnotes... Sorry for not directing you there right away.
Was there any other questions that you had?
