how many icons should there be for lcdc
wbarnette
Post by wbarnette »
I think that I may have too many icons running at the same time. What I mean is down on the task bar there are 4 icon numbered 1 thru 4 all say lcdc initializing. I down loaded 1 copy of lcdc from the website, then found the copy on the disk. I registered the copy and went back to start working with it. now when i start the configuration screen it can't find it but it's up running! is 1 copy blocking the other?
You should have only one icon, if you are using only one display. If you have too many lcdc copies open, and you set the com ports the same, there will be a conflict error on one of the lcdc instances.
