I have a MX212 and love all the features this unit has.
I want to start using it to control my fans, so my questions are:
1. An unmodified floppy cable = plain 'ol floppy cable from the PSU?
2. You either power the unit via the floppy cable or the USB cable not both right?
3. Are there any jumpers or soldering involved to make the fans (12v) run when connected?
4. Is there a max. amperage/wattage for each fan header?
5. Once you assign a function to the arrows on the unit, can it be used for another operation (i.e. right now my up/down arrows control the volume and I also want it to control the speed of each fan)?
6. What does PWM stand for and how is it used to control fans?
7. The majority of my fans do not have an RPM sensing wire. Can I still control the speed of the fans with the unit manually or automatically via temp. readings from MBM5?
