I had the PWM running a set of LEDs on my Matrix Orbital LK202-24-USB working perfectly.
As the project has been a work in progress I has not connected up the LCD in a while.
Now the PWM does not work at all.
The outputs switch on at power up, but will not turn off in test mode or by the events command.
I have tried all the PWM commands and GPO commands in the manual but none will make the output change.
[##254,87,1] and [##254,86,1] and the PWM commands.
I have this same effect on all HPO outputs, all the connections are wired correctly.
The LPO work just fine.
PWM will no longer work
http://www.ZapWizard.com
-Advanced Computer Modification-
