LK204-24-USB Temp Probes
McGreggor
Post by McGreggor »
I'm going to be using about a dozen or so temp probes, and i'm just wondering how I will be able to assertain which probes are which for LCDC setup. (If i wire in several probes to the same plug) I know they all have a uniqie 64bit code, is this marked on them somewhere?
Also, if i order the probes from RS Components, do they come as bear sensor or with wire/plugs? Do you have a part number for the required plugs too if needed?
Thanks in advance.
When you detect the probe on LCDC there will be a 64bit unique code generated. Once you get that code generated you can match it up with a code that is printed right on the head of the temperature probe.
If you order the probe from RS Components or some other company, you will only get the sensor. You won't be getting any wires or connectors that come with it. If you want to get the connector yourself, you can get it at molex and the part number is 173981-3 .
