Need help from Matrix Orbital!
Rickard
Post by Rickard »
Check out my case in the pic below.
Do you have an LCD that will fit in my 2 3.5" places below my floppy? Thats the only space i have left. Would also appreciate to know what other stuff i need to get it to work, like serial cables etc..
I saw your posts on some UK boards :wink:
I would recomend using the MK2041 which is a mounting kit. Glue the two blank inserts together and then cut out a hole for the LCD.
This GLK12232-25 was mounted in 2 3.5 drive was by doing exacly what I said. Then you need a power and serial cable.
_________________
<font size=-1>[ This Message was edited by: Henry on 2002-01-03 15:28 ]</font>
Rickard
Post by Rickard »
Thanks Henry!
This is the info i needed. I will place my order right away :smile:
NP :grin:
gordy_hand
Post by gordy_hand »
Would a four line lcd fit in there henry ?
Gordy_Hand
A GLK12232-25 is the same physical size as a LK204-25 (4x20 LCD)
gordy_hand
Thought it was ruffly the same :smile: Ta :smile:
Gordy_Hand
