I am using the VK204-24-USB with DS18S20 1-wire Dallas probes to measure case temperatures.
I am able to read the temps using the MXtest program or LCDC.
However, I wish to use Girder to communicate with the GPOs and therefore read the probes temperature. Ideally I do not want to run LCDC in the background as it would seem like bloatware to me for just reading the temperature. I am already able to communicate with the device via Girder's LCD Driver plugin. I assume it is not possible to communicate with another program if one application has already established communication with the device. Therefore, I think my only option is to somehow send RAW commands to the device for temp readings?
Is this possible?
Regards,
Marc.
can Dallas 1-wire probes communicate with Girder ? :-?
E-mail me and I'll get you what ever displays you want henryj@matrixorbital.caMMcM wrote:I have looked at adding better support for the VK204-24-USB in Girder. However, there are discrepencies in the manuals and I do not have one to experiment with. See, for instance, this post.
LCD 3.2 now available
The latest version of the Girder LCD plug-in includes support for temperature and fan monitoring.
