Help!!! LK202-24-USB
wotoni
Post by wotoni »
Ok... Here is the full history of what I have done to try and get this display to work. Any help is greatly appreciated!
I just recently got this display 2nd hand. No software cd/cables/etc... I found the drivers after searching this forum. Found the USB drivers, installed them and the OS recognizes it. I downloaded the Universal LCD Software, and it couldnt find the display.
After searching these forums again, I discoverd the changing of types on the LK202-24-USB in the LCD DB from the default (0x02 i think) to 0x36. The LCD Tester now communicates w/ the display. Yet I still couldnt do anything with it. I read in these forums to place a jumper on pins 6 & 7, power up the display, then remove the jumper. That will reset the comm speed. I then made sure all the comm settings were set to 19200 (in all progs I used to try and communicate w/ the display and the sys). The LCD Tester was able to communicate with it. I am now able to turn on and off the backlight and turn up and down the contrast. That is it. Cannot put any text or graphs on it. I had tried LCDC and yet I cannot display any text. HyperTerm was config'd correctly (atleast I think it is config'd correctly) and yet it could not communicate w/ it. Just a blank screen.
The display itself looks as if all the character blocks are lit (every pixel turned on) yet I cannot clear them. I do not get a boot logo either.
I have tried looking for the Display Tuner and found links on these forums, but the links are dead.
This is my sys config:
P4 3GHz HT
1GB Dual Channel DDR Memory
WinXP Pro
Display connected thru USB A/B cable to USB 2.0 port Configed on Comm3
Odo.[oni]
Webmaster of WoTOni.com
Hello...
What happens when you adjust your contrast levels???
wotoni
Post by wotoni »
Greetings! Sorry it took so long for me to respond, but evenings are the best time for me to respond.
Here are 2 links of the LCD Display Contrast Settings.
Here is the LCD w/ the default contrast settings:
http://www.wotoni.com/matrixorbital/LCD ... Normal.jpg
Here is the LCD w/ the contrast at full:
http://www.wotoni.com/matrixorbital/LCDContrastFull.jpg
Thanks and any help greatly appreciated!
Odo.[oni]
wotoni
Post by wotoni »
dum de dum de dum. Still waiting for a response.
Couple of my Electrical Engineer friends and I were trying to get this display working and discovered that it is not initializing properly. Is there any way to reset this display? I would like to try the override procedure yet I do not have the Display Tester Program as I do not have the disk. Everywhere I try to download it, all I get is a page can not be displayed message.
This is getting quite aggravating and poor support. Yes, I know it is second hand, but I have seen another post where the person (8balls LK202-24-USB dead? in Hardware Forum) received some help. His problem sounds just like mine.
Odo.[oni]
Can you email be at myero@matrixorbital.ca and I'll send you a software program and a memory chip file that will reset the module to factory default settings.
wotoni
Post by wotoni »
Email on its way! Thanks!
Odo.[oni]
wotoni
Post by wotoni »
Boy, great response time...
I have sent 2 emails, and yet still nothing.
First email was sent on 03/04/04 and the second on 03/09/04. It is now 03/23/04 and still nothing. I am still waiting for that software program and memory chip file.
I can be emailed at webmaster@wotoni.com.
Odo.[oni]
I have looked at my email history and have not received an email from you. I ensure you that if I was emailed you would of received what you required rather quickly!!! Please see your email as I will send you the appropriate information immediately.
Johnny
Post by Johnny »
Miles wrote:I have looked at my email history and have not received an email from you. I ensure you that if I was emailed you would of received what you required rather quickly!!! Please see your email as I will send you the appropriate information immediately.
Miles im still waiting on those files for resetting the MX222 display its been a week since i emailed you?
sorry for the thread hijack but i suspect there is something wrong with your inbox?? <:)
Try sending me an email again...very strange... :-? :-?
