Need help with my GLK24064-25!!!
natanel_r
Post by natanel_r »
I have just got the GLK24064-25 but I don't know how to make it show the information of my system just like the picture in the Matrix Orbital website!
How did they do that???
Here is the picture: http://209.35.221.142/pix/l24064-mother-yg-600.jpg
Hello...
This picture is a bitmap that is loaded to the display accordingly. Depending upon the type of information you want to show and where you want to show it, a bitmap can be used in conjunction with your firmware application. For example, if you want to display the temperature with a thermometer next to it and have the two adjust as the temperature fluctuates, then a bitmap will need to be generated in a selected position. As the temperature rises, the text will change and the thermometer can be changed by adding the additional pixels and etc...!!! :D
natanel_r
o.k....
Post by natanel_r »
o.k.......
Can you pleae tell me with what application have you done it?
Thank you....
Natanel.
This bitmap is just an example....You can just about display anything that is required. Depending on the type of system or environment you want to utilize the display for....things like temperature, humidity, wind speed, wind direction etc, can be visually represented...
natanel_r
sorry for bothering you....
Post by natanel_r »
I'm new with all of this...
Can you please explain to me from the begining how to do all of this?
Thanks..
Hmmm...where to start...what do you intend on using the display for?? :-?
natanel_r
Hello again....
Post by natanel_r »
I want it to show my system information (cpu speed) and the winamp information... And also cpu temp <:) ...
How much memory left on both hard drives
Stuff like that....
