Contrast ruins display when screen is "started"
fewture
Post by fewture »
I have a new MX212 with the new gpo control revision etc. Whenever I start up the display for the first time (like powering it up) from all angles including front on, its perfect. However when I start the screen (from something IVe done in screen builder or even the default one) the contrast goes very heavy so I can only see the words at extreme angles. If I look at directly I cant see anything, its all blurred etc.. heavy contrast etc.. I tried the display tuner and worked out it was the contrast.
Do I have to use the display tuner to manually override LCDC? The contrast value in LCDC is default ie 55. I also have a MX213 and it did the same thing. Please any help would be greatly appreciated.
Mat-Moo
Post by Mat-Moo »
LCDC overrides any values set, the mx212 is an inverted display, becuae of this you have to invert the contrast, I'd suggest setting it to 35% and see what happens.
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
fewture
Post by fewture »
thanks for reply. Yeah well i tried that with the mx213 and it didnt work but it has for this one. :)
