GK24064-25-vtp-e WONT WORK RIGHT HELP!
Ok i baught this awhile back just got around to using it bout a week ago now worked fin uploded text images and stuff was great. All of a suden it wont diplay any text. i retest the baud and now it's showing all the images i uploaded on one screen, and wont respond to anything... so i resett the baud with the jumper now same thing but this time it let me clear the screen... i drew a picture and it sent it but only displayed in the top left corner of the screen... i reste the baud again not sure what eles i could do tryed wipeing the module still nothing.... now it's back to displaying all the images crooked at once.... not sure what eles to do HELP!
You done the factory reset as per the manual? You DID look in the manual didn't you? http://www.matrixorbital.com/manuals/gl ... /index.htm
Try this:
- power display off
- put jumper on the reset-pins
- power display on
- set required baudrate in the software, using the default baudrate (so connecting with the default baudrate)
- power off the display
now it should use the baudrate you set while the reset-jumper was connected.
- power display off
- power display on
...whatever, as if I care...
Hello...
There is a possibility that the memory chip, for some strange reason, may of been corrupted or faulty during the download procedure. You can contact me at myero@matrixorbital.com directly and we can discuss your RMA options. Perhaps if you have any soldering capability we can send you a new memory chip and you can install it!
update:
Ok after alittle more playing around i found that i can do a direct write to the screen with MOGD and then i can get it to sespond but it then only outputes garbled jiberish until the screen is full.... then it lets me clear screen but nothing eles..... I think it's RMA time i got the sheet but what exactly do you need me to do....
-Shane
-Shane
Contact Miles at myero@matrixorbital.com directly and he will discuss your RMA options.
