It is currently Sat May 25, 2013 3:42 am
 Page 1 of 1 [ 4 posts ]
Author Message
 Post subject: That I do not so
PostPosted: Thu Nov 11, 2010 5:37 am
I send a command use GTT support tool "Load Bitmap to Buffer" Index:10, Filename: c:\b1.jpg (254 95 10 99 58 92 98 49 46 106 112 103 0)
Also I receive the answer
"The specified filename was not found" (252 95 00 01 00)
stm
Offline
 Profile
 Post subject:
PostPosted: Thu Nov 11, 2010 4:23 pm
Hello stm,
I see a few common mistakes here, and I think I can help you out.
First, any images you wish to display must to be saved on the SD card connected to your GTT. You can do this via the onboard USB connector by powering up with the unit in mass storage mode.
When saving your images, keep things simple and don't use any folders. Also, take note of the file names and sizes.
Next, to load an image, make sure you are in communication mode, then reference the image by name only, without the file path.
That should do it, but if you have any more trouble, please don't hesitate to post.
_________________
Offline
 Profile
 Post subject:
PostPosted: Fri Nov 12, 2010 2:15 am
Thanks for the answer, I have understood all. I will mandatory write about results.
stm
Offline
 Profile
 Post subject:
PostPosted: Sat Nov 13, 2010 12:42 am
Commands "Load Bitmap to Buffer" and "Display Bitmap" and also would work only with files of type "jpg", with files of "bmp" and "gif" the result isn't present.
Best Regards, stm.
Offline
 Profile
Search for:
Jump to:
cron
