LK204
TuxBully
LK204
Post by TuxBully »
Duno if it just me or something is wrong with the unit. I have the following configuration
LK204USB display using the internal USB connector with 3 SlientX 120M case fans connected and 1 unmodified floppy connector.
Licensed and install copy of LCDC version 1.07 Build 35 running on Vista
Now onto the problem in hand...
The display illuminates @ boot my fans are humming along and everything appears to work as expected until I start LCDC. Once I click on the Start Display button all of my fans turn off. At this point everything works from the displays perspective i.e. Stats are displayed and the screen is changing as directed from the configuration. Is this expected behavior? Do I need to configure something for the fans to remain on?
Hello TuxBully,
Thanks for your post.
I would like to refer you to LCDC's forum:
http://lcdc.planetdps.com/
