GTT29A keypad illumination isn't working
jamesh
Post by jamesh »
I have a GTT29A and display backlight works fine. LED indicators work fine. The only thing I can't get working is keypad illumination. I'm initializing like this:
gtt_set_auto_backlight(&gtt, 9);
gtt_set_keypad_backlight_time(&gtt, 0);
...and I'm setting brightness light this:
gtt_set_backlight(&gtt, 255);
gtt_set_keypad_brightness(&gtt, 255);
Is there anything I'm missing?
Re: GTT29A keypad illumination isn't working
Hello Jamesh,
Thank you for contacting Matrix Orbital technical support.
Your code looks good; it would keep the keypad backlight brightness to max 255 (which is the default setting).
Can you tell me what is not working?
jamesh
Post by jamesh »
The keypad won't illuminate so it's hard to see in the dark. It has never lit from the first time I powered it up until now.
Hello Jamesh,
The keypad on the GTT29A is default on; perhaps the LEDs on the keypad are broken?
Do you have the serial number on your GTT29A?
jamesh
Post by jamesh »
Raquel wrote: Fri Sep 22, 2023 3:03 pm Do you have the serial number on your GTT29A?
Serial # is 21M07-0454 . The haptic motor also has never worked.
I sent you an email, James.
We may please continue correspondence from there.
Thank you.
