EVE Screen Editor (ESE) 4.4.0
Version 4.4.0
Link:
https://www.matrixorbital.com/index.php ... t&did=1786
RC1
Features updates:
• Add the appropriate bitmap setup when dragging and dropping CMD_SKETCH into the emulator viewport
• Improve zoom-in precision
• Display the RGBA value along with the coordinate position of the cursor in the Emulator screen
• Enable drag and drop to open an existing project in ESE
• Update LibFT4222-64.dll to remove the dependency
• Show a warning message when the memory size required by CMD_SNAPSHOT2 is too large
• Give more explanation for the escape character usage in CMD_TEXT
• Improve format string example
• Auto detect and load the contents
• Widget alignment guide line
• Generate coprocessor commands once user drop an content item
Resolved issues:
• Removed glitched bitmap line in BT817 and BT818
• Fixed an issue that occurs when dragging and dropping an existing item in the Content manager
• Failed to build the exported project using MSVC
• Crash in a special PC with Qt6
raffaeler
Re: EVE Screen Editor (ESE) 4.4.0
Post by raffaeler »
Hi, I tried to use the release you linked, but I had major issues working with the bitmap as I described here:
viewtopic.php?f=45&t=6995
May I ask someone from Bridgetek to answer my questions?
Should I roll back to a previous release?
Thank you
Electronic Engineer, Senior Software Architect, Speaker, Trainer
Thank you for your post.
For software enquiries, please try Bridgetek's forum: http://www.brtcommunity.com/
