powering the GTT29A - which header accepts wide voltage?
I have the wide voltage (-VPT) version of the GTT29A and am successfully powering it with 5 volts on VCC at the serial header. Which header accepts the wide voltage option that the -VPT provides? The hardware manual only unambiguously mentions wide voltage at the Alternate Power Connector but that header isn't populated on mine.
Re: powering the GTT29A - which header accepts wide voltage?
Hello James,
The VPT model may work down at 5V but it is intended to work at 9-35V.
You should be able to supply power from either of these connections (I assume that you have a -CS model):
-Extended Serial Comm/ Power Header
-I2C header
The Alternate Power Connector is only for -USB models. Sorry for the confusion.
Hope this helps.
-I2C header
Hope this helps.
Yes, this is a -CS model and I'm happy to report that wide voltage works fine at the serial header as you suggested. Thanks!
