Correct manual for LCD2041 PCB rev1.4
raven
Post by raven »
I have an older LCD2041 lying around here that I never really used and now wanted to integrate into some new microcontroller projects. The PCB has "REV1.4" printed below LCD2041 on the back, but on the manuals site* I can only find manuals for "PCB revision 1.10 to 1.30" and "PCB revision 1.50". Which of these would be more accurate for the revision I have? Or is there one specific for 1.4?
David
* https://www.matrixorbital.ca/lcd2041-manual
Re: Correct manual for LCD2041 PCB rev1.4
Hi Raven,
I understand you are looking for the appropriate manual to use for your LCD2041 Rev 1.4.
Unfortunately, we lost LCD2041 Rev 1.4 documentation when transferring from old servers to the newer servers. With that said, you should be able to refer to the Rev 1.3 manual for display commands, and general information on setting up your display. If you have any questions regarding converting your display communication protocol, or if you have any specific questions that are not answered in the manual, feel free to post it up in the forums.
