jacklord
Post
by jacklord »
I plan to get the LK204-25PC lcd. Can I connect LEDs directly to the GPOs, or do I need to add a limiting resistor?
CyPher
- LCD Guru
Post
by CyPher »
unless your leds are 12V, then you will need to use resisters.
jacklord
Post
by jacklord »
I want to use 5v LEDs. What type/size resistors should I use?
Many Thanks.
GreatOldOne
- LCD Geek
Post
by GreatOldOne »
You can use this calculator over at Bit-Tech:
http://www.bit-tech.net/article/68/
If you supply it with the correct details, it'll tell you what value resistor you require.
