Trouble with Read Module Type in C#
PaulBMO
Post by PaulBMO »
When I execute this code (visual studio, C#):
//Read module type
commando[0] = 254;
commando[1] = 55;
port.Write(commando, 0, commando.Length);
int length = port.BytesToRead;
byte[] buf = new byte[length];
port.Read(buf, 0, length);
Console.WriteLine("Received data: " + buf);
I don't get the expected answer from the LCD.
Putting text on the screen and changing the font types etc, is no problem but receiving the Module type is./
What am I missing??
With kind regards,
Paul Joosten
BMO Offshore Measurements Systems BV
Rotterdam, the Netherlands
Tino
Re: Trouble with Read Module Type in C#
Post by Tino »
Hi Paul,
I assume you are getting something along the lines of 'System.Byte[]' being wrtten to your console.
Try this:
//Read module type
byte[] commando = new byte[2];
commando[0] = 254;
commando[1] = 55;
Console.WriteLine("Received data: " + buf[0]);
Note the change I made above in red.
This should work for you. You will see the response written on the console.
Thank you for posting on your forums.
Martino
Martino DeLeon
PaulBMO
Post by PaulBMO »
Hi Martino,
Thanks for your reply.
The problem was that I had to wait 50 milliseconds for the display.
So I added this line:
comport.Write(commando2Bytes, 0, commando2Bytes.Length);
int milliseconds = 50;
Thread.Sleep(milliseconds);
regards
Paul
With kind regards,
Paul Joosten
Tino
Post by Tino »
Hi Paul,
That's great that you found a solution.
Again thank you for posting on our forums.
Thank you
Martino
Martino DeLeon
