MOGDsharp bug brightness setting
RonHart
Post by RonHart »
In Modgsharp v 1.15 the brightness setting should used FE 99 while changing the slider, then FE 98 to set and save the value. Instead it uses FE 99 while adjusting followed by FE 91 which sets and saves the contrast (at the brightness level). The contrast appears to set and save correctly after adjustments.
I could not find a place to report bugs in the software, so it there is a better place to report it (such as an email address or bug report form) it would be good to place that link on the software page.
Tino
Re: MOGDsharp bug brightness setting
Post by Tino »
Hi Ron,
Thank you for your post and bringing this bug to us.
I have tested this and can confirm that this is a bug with MOGD# 1.1.5.
We will fix this in the next revision.
Thank you
Martino
Martino DeLeon
