multiple displays?
banished
Post by banished »
Can any of the software drive multiple LCDs? Indipendently? I would like to put one in my case and one on my keyboard. would they have to display hte same informaiton or could I have them showing different stats?
It depends on the software. LCDC allows you to have two copies of it runnig at the same time, so does LCD Center. So all you need is two displays on two serial ports.
banished
Post by banished »
Thanks Henry, you're always very helpful.
:grin:
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
You can generally mix software types too... say run the winamp plugin along side LCDC (sure you can have a winamp plugin in lcdc but why waste the memory of having the big lcdc running when a little winamp plugin will do?) :smile:
r.
