can the GPO be remapped?
using a GLK19264 and have been successfully communicating with it for a few months now. I can switch any of the 3 LEDs to any red yellow green or off. But i have one display that was used early in my code development that saw lots of garbage characters and now 2 of the 3 LEDs do not respond properly. Basically wondering if I inadvertantly remapped the GPO or something???? Top LED stuck yellow, Mid LED works fine, Bot LED stuck off.
I'm not sure what could cause that but lets try restoring the unit to factory defaults. Please put on the manual override jumper (See manual for details) and use mogd# to upload the attached filesystem image to the unit. Once uploaded it will be with a bit of luck be back to normal.
- GLK19264-7T-1U.ebin
- (16.46 KiB) Downloaded 312 times
