GX Typhoon w/ Silver Brushed Aluminum Bay insert?
WmMcNett
Post by WmMcNett »
Where can I buy a GX Typhoon w/ Silver Brushed Aluminum Bay insert to put in my Lian-Li PC-C32A Case.
Yes, I could have bought a Aluminum HTPC case w/ display for $300 - $700.
I've been searching for 2 days for a Display to put in the bottom 5.25" bay.
I've looked at;
Thermaltake A2331 Media LAB
COOLER MASTER RC-281-OSB1-GP Multi-media Kit
nMEDIAPC MCE VFD Module for nMEDIAPC's HTPC 288BA and SA cases
Silverstone SST-FP54-S Silver Case Front Panel With VFD Display
Lian-Li 3.5" Lintus Media Center - Silver (LM-01-S)
Moneual iMON VFD
SoundGraph iMON VFD
SilverStone Multi-media Display - Silver (MFP51-S)
Thermaltake A2328 / Media Lab VFD Panel / Silver
VLSystem's
L.I.S. MCE V.F.D. Display Unit
M-Play Blast
M-Play 202 Plus R2
My HTPC system so far;
LIAN LI PC-C32A Silver Aluminum ATX Desktop Computer Case
SeaSonic S12 Energy Plus SS-550HT ATX12V / EPS12V 550W Power Supply
ASUS P4P800-E DELUXE Motherboard
INTEL PENTIUM 4 3.4GHZ SL8K4
Thermaltake TR2TT TR2-M12 80mm Ball CPU Cooler
2 X Kingston HyperX 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit (4GB)
I'll have to enable The Physical Address Extension (PAE) to allow 32-bit Windows systems to use more than 4 GB of physical memory.
To enable PAE, use the BCDEdit /set command to set the pae boot entry option.
Windows Server 2003 and Windows XP/2000: To enable PAE, use the /PAE switch in the Boot.ini file.
bcdedit /set pae ForceEnable
EVGA e-GeForce 7600GT 512MB GDDR2 AGP 8X Video Card
LG Blu-ray/HD DVD-ROM & 16X DVD
Currently there is no silver PC Bay insert and at the moment there are no concrete plans to do so.
WmMcNett
Post by WmMcNett »
Now that's funny.
Was it not May of 2007 that some one said;
The GX Typhoon will come in 2 colours initially and 2 more colours will follow in the next 8 weeks. There will initially be Silver Brushed Aluminum as well as Black Aluminum PC Bay inserts.
Plans change.
WmMcNett
Post by WmMcNett »
I'll also assume that the plan about addons will/has also change.
WmMcNett wrote:I'll also assume that the plan about addons will/has also change.
No, those are upcoming... the first Digital Baybus addon prototype is here and we are tweaking right now... I should have some pictures soon...
Some of the Features:
4x Fan Headers at 12+Watts
2x 1-Wire Digital temperature probes
3x analog temperature probes (or 4)
3x GPOs
more info coming soon.
darklight_tr
Post by darklight_tr »
That sucks that it only comes in Black. I have a silver case and I prefer silver cases to black cases but it has become increasingly difficult to find silver bezel parts.
Just try finding a silver bezel optical drive. They seemingly have disappeared overnight!
