Ok, I'd like to order the graphical LCD GLK12232-25-WBL, and pick up the double drive bay mounting kit.
My question is does this lcd have a normal serial port connector attached to the back, or is it just pins? Is there a wire available I can buy that would work?
Looks like this lcd can run off an extra floppy power connector, so can I just forget about the included power cable in the drive bay kit?
See, told you I need help ... Thanks
Ordering help with GLK12232-25-WBL
The wbl has a 4BR serial header on it's back... order a 4BR cable and a normal 1' serial cable is you're mounting internally (the 4BR comes on a slot cover so you can use the 1' serial to loop around tot he serial port (this make the wiring tidier). Cheers,
r.
http://www.icehardware.net/reviews/graphiclcd/ - for a pic of it's back
r.
