Linux, serial port, strange chars on screen
ipl31
Post by ipl31 »
I had my lk204-25 working great with my laptop and linux using the LCD::MatrixOrbital perl module, although i had to hack it a bit to get it to compile on newer versions of perl:
http://www.evilsoft.org/Software/LCD.txt
Anyways, I moved the setup over a new computer, the permanent home. And it seems like now all I get is strange chars on the screen instead of the normal text. I have noticed that sometimes if I fire up "LCDProc" first and then start my script it seems to work ok. I am wondering if this is a character encoding issue or if my serial port needs to be initialized somehow.
Hi ipl31,
Thank you for your post.
The first thing to check when garbled text come up on the screen is the baud rate. Check that the baud rate is not changed somehow on your script.
ipl31
Speed
Post by ipl31 »
I have set the speed with setserial and it shows this:
stty -F /dev/ttyS1
speed 19200 baud; line = 0;
min = 1; time = 3;
-brkint -icrnl -imaxbel
-opost
-isig -icanon -iexten -echo
Do I need to change one of the other settings?
Hi ipl31,
I am not familiar with linux, but what I would like for you to check are the following:
baud = 19200
stop bit = 1
parity = none
flow control = none
