Changing Startup Screen in Perl (Linux)
Robert
Post by Robert »
Hi!
I'd like to change the startup screen on a LK202-25WB (installed on a linux system). I' using the following perl code.
open(LCD, ">/dev/lcd") or die "Can't open (write) to /dev/lcd: $!\n";
print LCD chr(254), chr(64), " WELCOME! BOOTING SYSTEM ";
close(LCD);
Unfortunately this code is not working :(
Other thinks work fine. I can clear the display, turn backlight on or off, ...
Do i need to use the remember function to set the startup screen?
Maybe somebody can help me.
Thanks!
Regards,
Robert
Paradigm
Post by Paradigm »
The set startup screen expects a FULL screen. A partial screen won't do. So you are going to need to send 40 characters after the initial 254/64 command. Give that a shot and let us know if that works.
James McTavish, P.Eng
Director of Engineering
AJB2K3
Post by AJB2K3 »
Ill confess here.
I changed mine in xp
i dont have perl installed so im suck.
