The module wasn't foound by "LCDC auto detection" and after that I get only "scrap" on any text I send to display!
Trying to use another com port has the same effect.
I also tried to use LCD Smartie and the same incomprehensible characters appeared to my screen.
I have connected the module with a straight through serial cable using the pins 2, 3 and 5 of each "sub D".
I also have to inform you that the startup message on module seems to displayed fine except the two verical lines appearing in the first segment of the upper line (I don't know if its normal)
Any help?
