I've been busy trying to port the blank delphi sheet to VB and VC++.
Seems it isn't possible to do it in VB since it has problems with the datatypes and can't export procedures.
In C++ its going a good way (no errors in testdll or LCDC), but it just shuts down the testdll or LCDC application .. Whej! I Made a LCDC_Shutdown Plugin lolz
is there a possibility to have an event, on the screen or with the gpo when a contact specific contact connect into msn ? like a gpo flash or the status of that contact on the lcd screen ?
working on that, but the current API of LCDC does not allow other languages as delphi for the plugin. Just have to wait till after version 1 of LCDC is released for mat to have time for the API i guess ...
This has been fixed in the newest version, I'm not sure why but the compiler has a probelm with tahat routine with optomisation on, but I've turned it off for that section and it works again. WIll be in the next release if I keep the project going.
In case anyone is in a hidey hole The latest release of LCDC (.098beta12) is now availble and has a whole load of new stuff, including Winamp graphics and Big fonts (on x4 displays only)
Mat is there a problem with 0.98B12 and XP Pro?, or compatability with older config files?, reason is, when I install 0.98B12 and run a config created by a previous version, all I get is the screen goes black, e.g all the pixels go black. If I deinstall that and reload the previous version when I created the actuall config, it all works fine. Any ideas?
