Screen display offset
Shadowhawk
Post by Shadowhawk »
I have an MX511 and recently the display lines has moved down one line, so the what used to be the bottom display line is now the top. The virtual display still displays correctly, it is just the actual unit. What can cause this shift and how do I fix it?
Hi Shadowhawk,
Thank you for posting at the forum.
Try uninstalling your display drivers and registry entries, and then do a fresh reinstall after. You can find the latest drivers and the location of the registry entries at http://www.lcdforums.com/forums/viewtopic.php?t=1016 .
Hopefully that works out for you. Keep me posted.
Shadowhawk
I removed all of the old drivers and removed any registry keys linked to them as per the other link and installed the new drivers and still the screen was offset. I even tried reinstalling the LCDC software and no joy.
Shadowhawk,
Can you test the display out on another PC? I want to eliminate the possibility that it is or not your PC causing the problem.
Shadowhawk
I do not have another computer to test the display on.
Shadowhawk,
Can you try to test it on a friends computer or you can try to remove all your other usb drivers? Sometimes you will have driver conflicts that cause strange things to happen like your problem. If you can replicate the problem with another pc then we can eliminate the problem is the pc. Also, you can try removing and reinstalling LCDC.
