VK204-24-USB text reverses with use of MyHD DVI Daughter Car
Joseph S
Post by Joseph S »
-Cards.
MB: ASUS P5AD2 Premium
MyHD 120 or 130 DVI Daughter card
VK204-24-USB connected to motherboard header
XFX 6600GT PCI-e
Unless I connect the DVI Cables in a certain order the VFD reverses the text. If I connect the DVI from the PCI-e card to the Daughtercard last the text may be normal.
The text is reversed from boot. If I power down and remove the looped cable the text is normal.
Any idea what is going on? Any way to undo this with Girder or similar app? Everything including the push buttons I have connected continue to function.
"latibro xirtam" (with letter draw normally/not flipped)
Are you using LCDC with your unit?
Joseph S
Post by Joseph S »
I have LCDC. but I'm using Girder with LCDMaster to control Push Buttons, Eject DVD Drive, View app status, etc.
The text is reversed on boot, prior to Windows or Girder loading.
Joseph S,
Could you please use a standard A to B USB cable as a test and see if this happens then too?
Joseph S
Post by Joseph S »
I'll try this later this week.
