I'm about to buy a MX222. MBM5 doesn't support or work with my DFI nForce 3 250 mobo...at least at the moment. What are my options for GPU and CPU temp monitoring? Am I stuck with having to use probes or is there other software I can use?
If my only course of action is a probe, frankly I don't even know how or where to attach them for proper CPU or GPU readings.
Thanks in advance.
MBM5 doesn't support my nF3 250 mobo....what to do?
Hi einsig,
Thanks for posting at the Matrix Orbital forums.
An option you have is to use a hmonitor software located at http://www.hmonitor.com/ in the download section. This plugin should work with LCDC which will display the contents shown with hmonitor. The plugin for hmonitor that works with LCDC is also located in the downloads section.
This should be easier than using the temperature probes.
For more information on LCDC go to http://www.lcdc.cc/about.htm and http://forums.lcdc.cc/index.php?act=idx .
If you have any further questions or concerns, please feel free to contact me.
We've been doing some stuff with M BM5 over at DF-street.com
Yes, full support for your DFI NF3
Full details and some stuff for Matrix Orbital MX421 here
http://www.dfi-street.com/forum/showthread.php?t=6798
works on DFI NF4 and NF3 with both XP 32-bit and x64 Edition.
enjoy, it's pretty kewl
course, still no x64 drivers for display (cough, cough, I know, it's being worked on
You can try speedfan as well http://www.almico.com/speedfan.php
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
I had exactly the same problem as the thread starter, same mother board and MB5 didn't work... The post quoted above fixed everything, so thank you very much! Im glad i got mine showing temp and stuff now...soundx wrote:We've been doing some stuff with M BM5 over at DF-street.com
course, still no x64 drivers for display (cough, cough, I know, it's being worked on)
