LCDC / MBM/ or ?
fishcrvr
LCDC / MBM/ or ?
Post by fishcrvr »
Just installed an MX202 kit and into my system.
MSI 865PE Neo2-PFS PLATINUM ED
INTEL PRESCOTT 3 GHz
Noticed that the display shows my processor as an AMD XP 3 GHz. :o
Also the temp readings are backwards to what MBM show in the task bar. It reads CPU as Case temp. :-?
Kind of figure this must be a software issue, but haven't any idea where to start.
knocker
Post by knocker »
hi just thought I would help im a newbie as well I have only just started to figure out some of the MBM settings my self is that the line from MBM3 in the LCDC setup menu which refers to AMD ?, I have the same CPU all I did was change the line to read P4 seems to have worked, its well worth popping back into MBM5 to make sure you have assigned the CASE /CPU correctly for your second question
I hope this helps :)
WHen the screens were first made, I did them on my AMD system... so... umm... ya...
fishcrvr
Post by fishcrvr »
Thanks for the pointers.........
Was able to get things working now.......... :)
Must say I am real glad the forum is here, would probably have pulled the rest of my hair out without it.
Thaks again..............
