LK204-24-usb Keypad Borked
wizeblood
Post by wizeblood »
Ive only had this MX4 for a couple weeks now and the keypad has stopped working. I was having a couple of other issues with my soundcard as well so I thought Id reformat. But still the keypad just doesnt work. Ive also downloaded the LCD tester from the downloads page and when I test the keys commands show up in the tester. So Im guessing theyre working but LCDC might be having problems.
Any Ideas?
If you see characters show up in LCD tester when you press the keys, then the keys are definitely working. Check if LCDC is working properly. Does everything else on your display also work properly, like contrast, backlight turning off and on, and text?
wizeblood
Post by wizeblood »
After testing all weekend it definately seems to be LCDC. If I press all the keys in LCD tester and restart LCDC they all work again. Everything else works fine on the display its just when I start my computer up I cant use the keys until I press them all in LCD tester then restart LCDC.
Ill try n find more in fo on the lcdc forums. Thanks.
