Motherboard monitor 5
The software LCDC does use MM5 feature, and the link for downloading the sample is below.
http://www.lcdc.cc/downloads.htm
One reason for having the ability to attach external temp probes is to take temperature reading other than what motherboard monitor allows you to do.
:D
ianschillebeeckx
Post by ianschillebeeckx »
When ever i start up the program my system speaker starts beeping...continuosly. Its only whne i start up MBM. The only way to stop the beeping is to restart comp. Any ideas?
-Ian
if i had to guess what was happening is that MBM is seeing a mis-reported CPU sensor thus setting off the alarm. Check your sensors that MBM has detected to make sure they are reasonable and not way off.
ianschillebeeckx
What am i supposed to do if one sensor is way off?
-Ian
ianschillebeeckx wrote:What am i supposed to do if one sensor is way off?
try a different sensor, as there is a number of different ones to select. Check to see if your motherboard is supported by MBM, and last, use the MBM support forum (search first ;) ) and see if they can help you out.
