GLK12232-25 SM Documentation PDF Error
psylence
Post by psylence »
Not a documentation error, but the PDF itself seems to be faulty.
The GLK12232-25 SM PDF, in the section where it describes settings for I2C and RS-232 is missing critical information (for my use at least!) :).
Page 10 of the PDF, the images at the bottom, the RS-232 is missing most of the caption text, and the I2C is missing the image and most of the caption text. Since this is the only description of the I2C setting, I'm lost! :geek:
Could have been a viewer compatibility problem, so I've tried Adobe Reader v6.0.1 (newest), and Ghostscript/GSview v8.14/v4.6, another computer with Reader v6.0 and another computer with Acrobat Reader v4.0 all with the same results as pictured below:
If the information could be posted here (or fixed of course) as to what modification needs to be done and which pins SDA/SDL are (the docs simply say it uses the same pins as RS-232, no order) that'd be great!
Can you contact me at myero@matrixorbital.ca and I'll send you the appropriate pdf file and hopefully this will work!! :D
