Fan control
Thermopyle
Fan control
Post by Thermopyle »
I'm considering purchasing a MX232 and was wondering about fan control...
If I understand correctly you can use LCDC to set the fans to come on at a preset RPM at a preset temperature. Can you configure it to ramp fan speed as the temperature increases? Something like this:
30 degrees - 50% rpm
40 degrees - 70% rpm
50 degrees - 90% rpm
60 degrees - 100% rpm
If not with LCDC is there ANY way to do this?
Thanks for any and all help.
NeilFawcett
Re: Fan control
Post by NeilFawcett »
Thermopyle wrote:I'm considering purchasing a MX232 and was wondering about fan control...
Yes, with LCDC you can do any speed any temp. The temps can be cpu or case as well...
AMAZING! OVER 180 views when I go to this thread and not one person had bothered to answer you...
