problems with an echo in keystrokes
BasieP
LCD Smartie
LCD Smartie
Post by BasieP »
i am making a way to get the buttons you press, but i have a problem:
When i press a button once, it is send to my PC twice...
So if i press the first button, i get the ascii value '8' to times
The manual says this, but i don't do it right, or it doesn't work
Auto Transmit:
If the auto transmit mode is on (default) then on any press of a key, the module will immediately send out the key code at the jumper selected baud rate. If auto transmit is off, when the poll command is sent, the module will immediately send the key code.
Keypad Interface (Both I
