I am running LCDC 1.03 Build 23 with the latest FRAPS plug-in on a MATRIX 2 line serial port display using def file LK202-25. The Plug-in is enabled, and configured with the following line: [#$FRAFra] FPS in order to display the frames per second, however upon starting 3dmark 2001 or max payne2 (Both Use DirectX) the plug-in fails to react at all. This is true for ALL available fields with in the screen builer in the plug-in. Please help me figure out what is going on here? Thank you in advance for any help.
-RIDDLER
FRAPS will not work...
Please upgrade to the latest version at www.lcdc.cc you are running a very old version.
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
